Strange rattling sound, dissapears when I apply slight pressure
Greg171
(@greg171)
Not sure why, but the printer has started making a rattling sound while printing. The sound stops when I apply the slightest pressure to the X axis pulley. Are there any parts that I can adjust that might alleviate this issue?
Link to video if the embeded video doesnt load
Opublikowany : 01/10/2021 11:54 pm
RE: check
Check to see if you bearings are too loose or too too tight. Also, check to see if any screws are loose.
Opublikowany : 02/10/2021 3:37 pm
Greg171
(@greg171)
adjust the bearings?
Screws have been tightened, tightened the x axis belt. Ran the belt tension test, came back as 254, which should be within acceptable limits. As far as the bearings go, how would I adjust them? I would think just replacing them would be the only solution.
Opublikowany : 02/10/2021 4:49 pm
Have the bearings been greased recently
If not try greasing now
Opublikowany : 04/10/2021 7:16 am
