Strange output from a good gcode file
Steve
(@steve-4)
I am trying to print an stl file that is included in the attachment.  I have included the .stl file, the gcode file, and the Prusaslicer parameters.  When I view the gcode file, it looks good, however, the print has overshoot at the bottom.
Can anybody tell me what is going on with the print and why I am getting the lower overshoot?
Attachment removed
This topic was modified 5 years ago by Steve
Senior Life member of IEEE.
Posted : 26/08/2021 11:29 pm
Dan Rogers
(@dan-rogers)
Y axis bearings?
Looks like major axis shifting - if this is the Y direction (left to right in your picture) that you are seeing that "over shoot", it is either your Y motor grub screws (tightened them in correct order) - or your bearing carriage clips are too tight (requires removing the heated bed plate to adjust).
Posted : 27/08/2021 6:04 am
A very long shot
This is extremely unlikely, but there was a bug in firmware version 3.8.1 that would cause something like this if you printed using OctoPrint.
Posted : 27/08/2021 2:12 pm
Steve
(@steve-4)
I found the problem
I found the problem.  The Y axis drive toothed pulley on the motor shaft was full of dirt/filament leftovers, and the belt kept giving resistance/overshoot when it encountered the stuff between the pulley teeth.  I took off the toothed pulley and cleaned it with a can of compressed air and an dental pick (the dental pick seemed appropriate since I cleaned between the teeth).  I also lubed the Y axis rails and bearings, and lubed the pulley at the other end of the belt.
I have a belt tensioner on the Y axis belt.  Have had it since I built the printer.  Works well.
Printer works fine now.  No overshoot.
BTW:  I have no idea what a "grub screw" is.
Posted : 28/08/2021 8:06 pm
