strange maxtemp hit? is this a slicer problem? mk3s+ and prusaslicer 2.4.0
Julian
(@julian-5)
hi, got this very strange looking graph (ignore the frog):
I'm going to check the gcode to see if it's generated by the slicer this way (I did import a project from an older version of prusaslicer)
I don't think this is a thermistor issue / cable issue as others on here have gotten though, the readings seem solid / stable, but the fact that the 'target temp' is bonkers at 1500 o.o
Best Answer by Julian:
ok, ignore this! this was all my fault.... had 'other layers' set to 1500 in the slicer... (threw me off since 'first layer' was correctly set), so it seemed to fail halfway
Napsal : 25/12/2021 4:35 pm
Julian
(@julian-5)
RE: strange maxtemp hit? is this a slicer problem? mk3s+ and prusaslicer 2.4.0
seems to be a gcode generation problem
Napsal : 25/12/2021 4:44 pm
Julian
(@julian-5)
Napsal : 25/12/2021 4:48 pm
