Stop Print Behaviour
Qlmmy
(@qlmmy)
I have minor annoyance. After I manually do a "stop print", on starting the next one, it says "resuming...". I have it stop it again, then select the next print one more fo rit to continue as normal. This hasn't caused any problems, I'm just seeing if this is common.
I'm running MK3S 3.9.3 and MMU2S 1.0.6
I'd be willing to poke around in the firmware code if necessary.
Opublikowany : 10/03/2021 4:39 am
RE: Stop Print Behaviour
Posted by: @qlmmy
I have minor annoyance. After I manually do a "stop print", on starting_ the next one, it says "resuming...". I have it stop it again, then select the next print one more fo rit to continue as normal. This hasn't caused any problems, I'm just seeing if this is common.
Are you using octoprint?
Opublikowany : 10/03/2021 4:43 pm
Qlmmy
(@qlmmy)
@cwbullet
No. I'm loading it from the SD and manually stopping the print from the menu.
Opublikowany : 10/03/2021 5:01 pm
