Stepper noise
Txema
(@txema)
Stepper noise
Hello,
During today's print I was hearing a noise (like a "clank...clank") that seems to come from the X-asis stepper when it's moving, but I don't know if it can be a problem of the stepper itself, perhaps a too much tensioned belt or any other kind of problem.
https://forum.prusa3d.com/wp-content/uploads/2022/02/Stepper-noise.mp4
Thanks.
Best Answer by Tim Weston:
It's a little hard to be sure from the recording, but it looks/sounds like the noise is occurring with each revolution of the stepper motor shaft.
As a first check make sure that the two grub screws holding the pulley on the X-axis stepper motor shaft are fully tight.
Cheers,
Tim
Opublikowany : 23/02/2022 12:36 pm
Tim Weston
(@tim-weston)
RE: Stepper noise
Cheers,
Tim
Opublikowany : 23/02/2022 5:10 pm
1 ludzie polubili
Txema
(@txema)
RE: Stepper noise
Thank you very much!!! After tightening those screws the noise has disappeared.
Opublikowany : 24/02/2022 11:08 am
Tim Weston
(@tim-weston)
RE: Stepper noise
You are most welcome!
Cheers,
Tim
Opublikowany : 24/02/2022 12:17 pm
