Stepper driver for Original MK3S+ stepper motors.
osre
 osre
(@osre)
after my MK4 upgrade I wanted to repurpose the remaining hardware of my MK3S+ to build a CNC.
I think FluidNC is a good choice for the software and I found a nice mainboard ready to use, but I need stepper drivers.
Which stepper drivers do I need? I was thinking on using the 2 Z motors for X and Y because of the nice long spindles, and use the X/Y motors for Z.
Also the actual motor data sheets would be a nice addition as well.
Thank you, Reinhard.
Veröffentlicht : 18/02/2024 2:31 pm
Patrick McNamara
(@patrick-mcnamara)
RE: Stepper driver for Original MK3S+ stepper motors.
The drivers in the Mk3 are from Trinamic.  The Mk3 stepper motors have a current rating of 1A, so it won't take much in the way of a CNC level motor driver.  Just don't expect to cut anything but the softest materials.  Stall torque is going to be around 0.2kg-cm.  Assuming I did the match right, and depending on the lead screw efficiency, you might get 1kg of force.
Veröffentlicht : 18/02/2024 3:36 pm
osre
 osre
(@osre)
Thank you for the info. I'm planning to engrave PCB's with it, maybe cut some acrylic.
And if it turns out to not work that great, I can always get some new motors and print some new parts. That's basically half the fun of it, isn't it?
Veröffentlicht : 18/02/2024 3:50 pm
