[Risolto] STEP source files for Original Prusa printed parts?
CovertPluto3502
(@covertpluto3502-2)
Prusa provided some STL files for the printable parts of the printer. I have seen that on their Github there are scad files for the MK2, but any source files for the newer printers? I'm trying to remix some parts for my printer, and some source files would have been very useful. Has Prusa provided these anywhere, at least I haven't found them yet.
Best Answer by bobstro:
Same place on GitHub. Hit the little drop box at top left to select which version (printer) you want.
Postato : 24/07/2020 11:57 am
RE: STEP source files for Original Prusa printed parts?
Postato : 25/07/2020 8:44 pm
CovertPluto3502
@bobstro
Yep, found it. The drop box has everything, including STL, SCAD and STP files. Just a note: some files may be in other places since they haven’t been updated.
Postato : 25/07/2020 10:41 pm
@covertpluto
Maybe you can use something from this CAD (Solidworks, STEP) data for yourself:
MK3S: https://www.thingiverse.com/thing:3434917
MK3: https://www.thingiverse.com/thing:2699771
MMU2: https://www.thingiverse.com/thing:3080920
Postato : 25/07/2020 11:00 pm
CovertPluto3502 hanno apprezzato
Rob
 Rob
(@rob-4)
could really use the STEP file for the LCD cover for the I3 MK3S. So far I have only found it as an STL not SCAD or STEP. If any of you have access to this file in preferred STEP or Fusion360 format, I would be grateful.
Thanks!
Questo post è stato modificato 2 years fa 2 tempo da Rob
Postato : 13/08/2020 2:49 am
@roblob
With FreeCAD, STL data can be easily exported to STEP data. With the result you can continue working and edit in many CAD Systems.
LCD-cover-ORIGINAL-MK3
Postato : 13/08/2020 7:14 am
Rob
 Rob
(@rob-4)
@karl-herbert
Thank you!
Postato : 13/08/2020 8:07 am
