Steel sheet selection option is gone from the printer's menu
feder
(@feder)
HI,
Recently I ran into strange problem. Menu position for steel sheet selection is gone in my mk3s with MMu2S. I can set options for specific sheets in HW Setup, but option to select the specific sheet is not being displayed.
I tried a factory reset and forcing firmware update but it did not help. Does anyone have any clue what happened?
Opublikowany : 28/02/2020 11:41 am
vintagepc
(@vintagepc)
RE: Steel sheet selection option is gone from the printer's menu
Do you only have a single sheet? I think it hides if that is the case.
It is most definitely still there for me (same setup, 3S/MMU2S), and I'm running the 3.9 RC.
Possibly worth noting it *did* get moved further up in the main menu, if you recently did a firmware update.
Opublikowany : 28/02/2020 2:16 pm
feder
(@feder)
I have three sheets, so switching them got complicated with this option gone.
I re-flashed last official firmware (3.8.1), so it should be where it always been...
I will try flashing beta FW, maybe it will help...
This post was modified 6 years temu by feder
Opublikowany : 28/02/2020 3:38 pm
Victor
(@victor-2)
Hi @piotr-f3
I have this same problem. Were you able to solve it?
PrusaMINI
Opublikowany : 26/11/2020 10:14 pm
Twilek
(@twilek)
Probably this is solved for the author but if someone encounters the same problem (like I myself did this morning)...
From the Prusa Help Database:
As soon as two or more profiles are configured (by the First Layer Calibration), you will be able to quick-toggle between them directly from the main menu.
Opublikowany : 14/01/2021 7:43 am
Elly
 Elly
(@elly)
The selection option disappeared on me too.
It was there when I had 3 sheets configured. Now I have 4, it is gone. Did anyone solve this issue?
Opublikowany : 29/08/2021 3:50 pm
Mark
 Mark
(@mark-12)
For anyone coming to this post looking for a solution here's what worked for me:
For each sheet you want active you need to do a new first layer calibration. Go to settings > hw setup > steel sheets then click on the sheet and select first layer cal.
As soon as you have two sheets calibrated it will add the option to change sheets
Opublikowany : 23/03/2022 12:12 pm
feder
(@feder)
I had  to make factory reset to restore the option and then calibrate sheets again.
Opublikowany : 23/03/2022 12:28 pm
