Steel Sheet Bending
alejo.v2
(@alejo-v2)
Steel Sheet Bending
Hello, I´m having some problems with my bed. When it´s cold or under 75°C , the bed is perfect, but when It´s heated above 75-80 °, it bends up in the center. It is peeled . it does not magnetize in the center.
I have it since 4-5 months, and I do not bend it too much to take out the pieces when are finished.
Did it broke or something like that? It´s a shame because I´m not able to print with carbon fibers filaments. I asked to purchase the coated steel sheet but they are not giving it. 🙄 😳
Postato : 16/10/2018 10:46 pm
Re: Steel Sheet Bending
Contact support if the sheet is truly defective. Explain the problem and they may send you a replacement.
You can order the double-sided sticker PEI sheets in the online store.
Postato : 16/10/2018 10:56 pm
Peter L
(@peter-l)
Also, the build plates are consumable; they're not expected to last forever.
Postato : 17/10/2018 2:58 am
alejo.v2
(@alejo-v2)
But i expected they last at least 1 year maybe. Don´t know.
Postato : 17/10/2018 3:26 pm
