Start new project in PrusaSlicer without restart?
An annoying behavior of Slic3rPE was brought over into PrusaSlicer. Once I slice objects, I can't find any way to get back to the original Plater UI with the add-object, lay flat, etc. buttons. I have to exit the program and restart. Is there something I missed?
Best Answer by Dave Avery:
click on the wireform cube in the lower left corner or Crtl-5 or 'window/3d"
RE: Start new project in PrusaSlicer without restart?
File - New Project doesn't work for you?
Nope.
@david-a66 has it. After slicing, you're in preview mode. Click back on the 3D Editor mode. The fact that Preview mode shows an empty bed after you make any changes is certainly confusing at times. Keeping the "unsliced" view would be preferable. This would be a good feature request over on Prusa's github.
Huh - was sure I had tried that. Thanks. And yes, I will make the feature request as it sure is confusing.
Feature request filed. "Working on it"
