Spinning heater block in V6 Hotend
I was attempting to replace the nozzle on my V6 hotend and noticed that the heater cartridge/block is spinning as shown in the video below. Is there a way to tighten this/fix this? I removed some of the screws for the fans and front cage to try to see if there was anything that I could do but I do not see anything. Any and all help is appreciated!
Napsal : 17/05/2023 1:48 pm
RE: Spinning heater block in V6 Hotend
If you twist it to the normal position it should tighten
Napsal : 20/05/2023 8:13 pm
