Spare grab screw / setscrew for Bondtech gear
Lichtjaeger
(@lichtjaeger)
Hello everybody.
I had problems with the extruder due to a loose Bondtech gear. But I can not tighten the setscrew anymore because the head is already too worn out. To order a new Bondtech gear because of a setscrew is unreasonable.
The setscrew itself is, unfortunately, M3 x 2mm, which is not a common size. Although I have found a provider, I really don't need 50 pieces 😐 .
If anyone has access to them, could you send me some please?
Opublikowany : 28/07/2018 6:52 pm
Re: Spare setscrew for Bondtech gear
should be a spare in your kit!
where are you located?
Joan
Opublikowany : 28/07/2018 7:59 pm
Lichtjaeger
(@lichtjaeger)
Re: Spare grab screw / setscrew for Bondtech gear
Let me see ... Yes, I found one inside a nut. 😀 Thanks.
Germany
But this doesn't solve the problem. What do I do next time?
Maybe I should ask some local companies if they have some in spare.
Opublikowany : 29/07/2018 9:33 am
Lupis1
(@lupis1)
If you have a local R/C hobby shop, they may have this typer of screw.
Opublikowany : 29/07/2018 10:06 am
