something started to smoke
Gavin-R
(@gavin-r)
I had this External SPI flash XFLASH is not responding  so I followed some information from https://www.help.prusa3d.com/en/article/external-spi-flash-w25x20cl-xflash-not-responding-error_112019
checked the plugs this didn't work so then I ended up unplugging the lcd and going the reflash option  which failed and I noticed smoke coming from somewhere near the PINDA side  and the bed was also hot
what happened to my baby
this is my flash log also
avrdude-slic3r -v -p atmega2560 -c wiring -P /dev/cu.usbmodem101 -b 115200 -D -U flash:w:0:/Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 10 2022 at 11:39:10
                Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : /dev/cu.usbmodem101
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
                AVR Part                      : ATmega2560
                Chip Erase delay              : 9000 us
                PAGEL                         : PD7
                BS2                           : PA0
                RESET disposition             : dedicated
                RETRY pulse                   : SCK
                serial program mode           : yes
                parallel program mode         : yes
                Timeout                       : 200
                StabDelay                     : 100
                CmdexeDelay                   : 25
                SyncLoops                     : 32
                ByteDelay                     : 0
                PollIndex                     : 3
                PollValue                     : 0x53
                Memory Detail                 :
                                         Block Poll               Page                       Polled
                  Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                  eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
                  flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
                  lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                  signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                Programmer Type : Wiring
                Description     : Wiring
                Programmer Model: AVRISP
                Hardware Version: 15
                Firmware Version Master : 2.10
                Vtarget         : 0.0 V
                SCK period      : 0.1 us
avrdude-slic3r: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude-slic3r: Device signature = 0x1e9801 (probably m2560)
avrdude-slic3r: reading input file "/Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex"
avrdude-slic3r: writing flash (251278 bytes):
Writing | ################################################## | 100% 44.95s
avrdude-slic3r: 251278 bytes of flash written
avrdude-slic3r: verifying flash memory against /Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: load data flash data from input file /Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: input file /Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex contains 251278 bytes
avrdude-slic3r: reading on-chip flash data:
Reading | ################################################## | 100% 32.24s
avrdude-slic3r: verifying ...
avrdude-slic3r: 251278 bytes of flash verified
avrdude-slic3r done.  Thank you.
avrdude-slic3r -v -p atmega2560 -c arduino -P /dev/cu.usbmodem101 -b 115200 -D -u -U flash:w:1:/Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
                Using Programmer              : arduino
avrdude-slic3r: prusa_init_external_flash(): MK3 printer emitted incorrect cfm code: `echo: 3.10.1-`
avrdude-slic3r: arduino_open(): Failed to initialize MK3 external flash programming mode
avrdude-slic3r: Could not open port: /dev/cu.usbmodem101
Napsal : 20/03/2022 5:56 pm
Gavin-R
(@gavin-r)
RE: something started to smoke
Napsal : 21/03/2022 12:14 pm
