something started to smoke
I had this External SPI flash XFLASH is not responding so I followed some information from https://www.help.prusa3d.com/en/article/external-spi-flash-w25x20cl-xflash-not-responding-error_112019
checked the plugs this didn't work so then I ended up unplugging the lcd and going the reflash option which failed and I noticed smoke coming from somewhere near the PINDA side and the bed was also hot
what happened to my baby
this is my flash log also
avrdude-slic3r -v -p atmega2560 -c wiring -P /dev/cu.usbmodem101 -b 115200 -D -U flash:w:0:/Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 10 2022 at 11:39:10
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : /dev/cu.usbmodem101
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude-slic3r: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude-slic3r: Device signature = 0x1e9801 (probably m2560)
avrdude-slic3r: reading input file "/Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex"
avrdude-slic3r: writing flash (251278 bytes):
Writing | ################################################## | 100% 44.95s
avrdude-slic3r: 251278 bytes of flash written
avrdude-slic3r: verifying flash memory against /Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: load data flash data from input file /Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: input file /Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex contains 251278 bytes
avrdude-slic3r: reading on-chip flash data:
Reading | ################################################## | 100% 32.24s
avrdude-slic3r: verifying ...
avrdude-slic3r: 251278 bytes of flash verified
avrdude-slic3r done. Thank you.
avrdude-slic3r -v -p atmega2560 -c arduino -P /dev/cu.usbmodem101 -b 115200 -D -u -U flash:w:1:/Users/gavinrobinson/Downloads/prusa3d_fw_3_10_1_MK3S/prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
Using Programmer : arduino
avrdude-slic3r: prusa_init_external_flash(): MK3 printer emitted incorrect cfm code: `echo: 3.10.1-`
avrdude-slic3r: arduino_open(): Failed to initialize MK3 external flash programming mode
avrdude-slic3r: Could not open port: /dev/cu.usbmodem101
