Solid Infill Bands
Hello,
MK3s here printing Prusament PETG.
I get these bands when printing solid infill. Mainly noticeable when printing translucent filament. I can't figure out what causes them. In this image they seem to appear in the direction of the extruder movement which is diagonal at 45 degrees. They seem to be smooth to touch (not bumps).
Has anyone experienced this?
I have tried varying belt tensions but they don't go away from that. Could it be artifacts of the stock stepper motors?
(Band direction indicated in red).
Opublikowany : 07/08/2021 1:30 am
Print speed
If they are the same thing I see, I have seen these increase with print speed. Slow it down and see if they reduce.
Opublikowany : 07/08/2021 9:40 am
