Small bug in 3.5.3 Firmware
Kjeld
(@kjeld)
Hi Prusa
I found a small bug in the 3.5.3 firmware.
Wen you long-push the nob to raise the extruder, then:
When you want to go back to the main menu, but accidently makes a long-push instead of just a short push the nob doesn't respond to any push any longer.
I was able to take the SD card out, and put it back in, and then got back to the main menu that way.
Best regards
Kjeld
Publié : 13/04/2019 10:18 am
Kjeld
(@kjeld)
Re: Small bug in 3.5.3 Firmware
Hi Prusa
I try updating the firmware to 3.7.0-2201, but the problem didn't disapear.
If you long-push (instead of short-push) to go back to main menu then the nob stops responding to any push
Best regards
Kjeld
Publié : 13/04/2019 10:40 am
