Slight misalignment - should I fix this?
Hello
I try to make a timelapse and while trying I've seen a misalignment.
If you look in the attached image you will see 3 horizontal lines and the upper line is not parallel with the middle line.
On my Prusa I have a bed uniformity problem, can this be the problem? Can I fix this?
Thank you.
Respondido : 03/05/2020 4:15 am
