slicing issue with prusaslicr
ametwalyhsgca
(@ametwalyhsgca)
There seems to be an issue when prusa slices my object, for instance, I used the provided 3D object from prusa for the enclosure kit, the PSU stabilizer for the MK3s. This issue happens when  theres a higher wall that will be incoming for the object. Please look at the pictures to see what I mean what im talking about, Thank you
this layer lines is suppose to go around at the edge, but theres no structure under it.
Postato : 01/04/2021 2:39 am
RE: slicing issue with prusaslicr
Hard to diagnose without additional information.
For questions like this, it helps if you save your project as a .3mf file from Prusaslicer. Simply load the STL into PrusaSlicer, then under File, use Save project to create the 3mf file.
Unfortunately, this forum does not allow the upload of 3mf files, so you'll have to Zip it before you can upload it here.
The 3mf file contains not only the model but also all your settings information, so folks here can take a closer look.
Postato : 01/04/2021 12:30 pm
1 persone hanno apprezzato
Swiss_Cheese
(@swiss_cheese)
That's just the bridge fill, you have several more layers to come, slicer is working fine, Allow the part to finish printing and complete your project.
Enjoy
Swiss_Cheese
The Filament Whisperer
Postato : 02/04/2021 12:15 am
Dan Rogers
(@dan-rogers)
Does the part have a little triangle with an exclamation point in it next to the part in the part list in the plater?  Click that.
Postato : 02/04/2021 7:47 pm
