Slic3r & PrusaControl hangs
sjoerd.g
(@sjoerd-g)
Hello,
I've been running into issues with both PrusaControl and Slic3r hanging on my system most of the time. I've managed to narrow down the problem to having multiple screens attached to my system. In either piece of software, if it tries to create a 3d viewport in a window on a screen that is not on the primary monitor, the software hangs, and the only thing you can do is kill the application using task manager or the not responding dialog.
I tried updating to the latest version of the driver package (2.1.5) and also tried the official slic3r software (1-2-9a-stable), and all show the same problem.
The only real workaround I've found so far is disabling all screens but one and running the application, otherwise the chance it will lock up is quite high.
Would be nice if someone could look into this.
Thanks!
Posted : 17/05/2018 11:17 am
