Slic3R PE in Linux
Due to circumstances I have to switch from WIndows to a Linux distro on my laptop.
COuld someone point me out to the correct info on how to install Slic3rPE on Linux?
Thx!
(Mint Linux 19)
Postato : 24/09/2018 10:10 pm
Re: Slic3R PE in Linux
No install required of you use the appimage. I run this on Mint and it works fine.
Postato : 24/09/2018 10:27 pm
RE: Slic3R PE in Linux
I tried this too, but does not work on 32Bit linux systems. See this post:
Any other Idea?
Postato : 28/04/2019 5:53 am
So you have a 32-bit Linux? In 2019? Why?
If you want to get that working, you'll likely have to compile Slic3r-PE from sources. It's not that hard.
Or use a distro that ships it pre-packaged. openSUSE Tumbleweed has Slic3r-PE packages available for 32-bit, unfortunately a rather ancient version (1.38).
Postato : 28/04/2019 1:57 pm
