Slic3r PE bad allocation error
xander.j
(@xander-j)
Hello, I have recently been attempting to slice a model in Slic3r. Im using the Prusa MK3 MMU2 presets but no matter what I do, I cannot slice without receiving a "bad allocation" error. This issue does not appear with any other models nor does it happen when I slice the file without the MMU2 enabled. I have attached a screenshot of the error and the file I've been attempting to print. If anymore info is needed, please let me know, because Im trying to get this printed for a competition soon. Thank you so much 😀
Edit: I cant attach the .STL file but if you need info I can give it to you, sry
Publié : 12/04/2019 8:23 pm
Re: Slic3r PE bad allocation error
To post STL files, and other types as well, first place them in a ZIP container (compressed folder), then attached them to the post.
Publié : 13/04/2019 9:24 am
Peter in Katy
(@peter-in-katy)
Did you change your extrusion width?
If so, set it back to default.
Publié : 13/04/2019 2:11 pm
soren
(@soren)
RE: Slic3r PE bad allocation error
did you ever figure this out? So incredibly annoying to encounter this mystical error after 10 hours of assembling stuff
Publié : 08/05/2019 1:52 pm
