Slic3r PE 1.41.2+ presets
JEC1965
(@jec1965)
Hello All, new to printing and the i3 MK3. I read the article by Mikolas Zuza about larger extruder nozzles and he shows options in the pull down for .25 and .6 nozzles. I downloaded the Slic3r PE 1.41.2+ from the Prusa site and it does not have those options. Do I need to install something else or configure it?
https://www.prusaprinters.org/everything-about-nozzles-with-a-different-diameter/
Opublikowany : 27/01/2019 4:29 pm
Sembazuru
(@sembazuru)
Re: Slic3r PE 1.41.2+ presets
You may need to run the configuration wizard again.
Here is where in the menus to launch the wizard:
And here is the wizard, note I have the 3 nozzle sizes selected for my MK3 printer:
So you can see the 3 options in my printer preset pull-down.
I hope this helps.
See my (limited) designs on:
Opublikowany : 27/01/2019 6:29 pm
JEC1965
(@jec1965)
Thank you very much that fixed my configuration.
Opublikowany : 16/02/2019 3:17 am
