slic3r 1.41.2 profiles not saved
i use latest slic3r PU 1.41.2, i've added some profiles, each profile loads the trio printer/filament/print settings, i set octoprint in every printer, i save and all works great, but when i close slic3r, i lose some print and filament setting, but i have always all the printer settings, it's the 4th time it happens, do i make something wrong?
Postato : 29/11/2018 2:44 pm
Re: slic3r 1.41.2 profiles not saved
Ah, I have this problem now too 🙁
I'm not sure how this happens or how to fix it, but do you know if worked on previous Slic3r PE versions?
Good luck!
Hi! I'm Mathieu!
Thingiverse: https://www.thingiverse.com/BramForReal/about
YouTube: https://www.youtube.com/channel/UCh-2bXtfv-nLwgwO7H7IJxA
I have an Original Prusa i3 MK3 with MMU 2.0. Nice meeting ya! 😀
Postato : 01/12/2018 1:13 am
