Single full step (Z) increment in mm?
joshua.w6
(@joshua-w6)
Trying to confirm how many steps the Prusa MK3 stock stepper motors have per revolution?
Is it a standard t8 leadscrew?
On my monoprice select plus, it worked out so that a full step was 0.04mm, so I setup all my software to ensure everything was done in full step increments. I am hoping to understand the setup for the same on my MK3, but am having troubles finding details on the Steppers and leadscrews on the MK3...
Opublikowany : 23/04/2018 12:26 am
reid.b
(@reid-b)
Re: Single full step (Z) increment in mm?
Are you reading this forum???
https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/motor-step-angle-and-screw-pitch-for-mk3-1-8-and-8-t15666.html
Opublikowany : 23/04/2018 12:32 am
joshua.w6
(@joshua-w6)
Thanks reid.b!
At first I was snippy for the salt that came in your reply, but then I realized what you meant. Yeah, total duplication of alan.e22's week old post. My bad!
There is a ton of content in the forum, which I've been working my way through, but yeah, missed that for sure.
Appreciate it!
Opublikowany : 23/04/2018 1:23 am
