Sheet selection no longer shows up at menu top level
Talinseven
(@talinseven)
When I first got my mk3s, and switched from the smooth plate to the textured plate for the first time, the sheet selection show up in the top menu level (in addition to being buried in settings). The top level is no longer appearing. Has this changed in fw? Should I reload my fw?
Best Answer by Talinseven:
Nevermind. I see that you have to have two or more Sheet first layer calibrations set for the menu to appear.
Opublikowany : 24/10/2021 4:15 pm
Talinseven
(@talinseven)
You must have 2+ 1st layer calibrations saved
Opublikowany : 24/10/2021 4:19 pm
