Setting Default of Z-Axis Higher as a default?
Tech Support Question:
Anyone know how to do this? How do I raise the Z-axis in the configuration (as a default setting) so it does not sit 2mm from the bed after an auto home or any time the printing is stopped. I am finding that I regularly need to raise the Z-Axis in the settings menu to clean the tip or access the removable print bed. I would like to raise the default position to somewhere around +.80 to +.100 above the bed.
Postato : 24/02/2020 5:43 pm
