[Rozwiązany] Selfteste error: Axis X
Nils | Frreiheit
(@nils-frreiheit)
Hello,
we built the printer kit and now everytime we get the issue
"SELFtest error!
Please check:
Axis length
Axis X"
and don't know what to do? (We actualised the firmware already from some of 2021 to the newest and read the following: https://help.prusa3d.com/article/check-axis-length-x-y-z-mk3s_134223)
Best Answer by Nils | Frreiheit:
Hello again. 🙈
I were able to fix the issue.. not sure what exactly it was. Because of another problem I had to re assemble the nuts of the Z-axis and then it workt one time - the second time not. At the end it helped to re assemble the motor of the X-axis so that every test was a success.
Maybe the volume wasn't perfect on the motor.
Opublikowany : 03/02/2024 5:42 pm
TechTiger
(@techtiger)
RE: Selfteste error: Axis X
I'm suddenly getting the same error on a machine I assembled years ago.  The link above seems to be broken.
Opublikowany : 04/02/2024 7:55 pm
Nils | Frreiheit
(@nils-frreiheit)
My bad. :/
I asked on a Discord server now too for help and tried to cut down the zip ties more - that didn't change anything yet, but I will check my belt tension again using the following description: https://help.prusa3d.com/article/adjusting-belt-tension-mk3-mk3s-mk3s-mk4_112380 (I will tell you here if that will work or not)
And for your comment that my link above doesn't work: https://help.prusa3d.com/article/check-axis-length-x-y-z-mk3s_134223 (sorry 😅 added a ")" at the end which "defects" it)
Opublikowany : 05/02/2024 6:10 am
Nils | Frreiheit
(@nils-frreiheit)
Hello again. 🙈
Opublikowany : 07/02/2024 12:49 pm
