Página 2 / 2
Anterior
RE: Self Test Error - Please check axis length Y
@jwvanderbeck, you won't see an obstruction, it is just the lack of lubrication causing the sensors to malfunction. I used the lube that came with the kit, but any white grease should do it (google 3D printer lubricant). I applied a bit to a paper towel and ran it along the two smooth metal rods under the print bed. Then I manually slid the print bed back and forth and repeated until it all moved nicely.
Respondido : 02/08/2023 11:59 pm
Y axis error after unit was sitting a long time and I did a fw uppdate.
Clean and grease the rails fixed it.
Respondido : 28/06/2024 7:02 pm
Página 2 / 2
Anterior
