[Risolto] Selection of Sheet Profile
Matthias
(@matthias-6)
Hello everybody,
With the firmware 3.8.1 and the new feature sheet profile I defined 3 sheet profiles (pei, powder and lokbuild). Each sheet needs a different calibration of the first layer. When I try to select the correct sheet profile from the LCD menu, I can only toggle between profile 1 (original name smooth1) and profile 3 (original name texture1). I haven't found a way to select another of the predefined sheet metal profiles.
Thank you for any advice.
Postato : 13/12/2019 6:29 am
Lichtjaeger
(@lichtjaeger)
RE: Selection of Sheet Profile
You must do a first layer configuration form the hardware setting menu before the profile shows up at the main menu.
Postato : 13/12/2019 7:58 am
Matthias
(@matthias-6)
That's it. Many thanks.
Postato : 13/12/2019 8:24 pm
