Selecting nozzle and bed-surface via printer-interface
Hello,
I have recently switched to a 0.6-nozzle. So I chose the right profile in PrusaSlic3r ... exported to sd-card, sd-card into the printer ...
but then my printer gave a warning, telling me I had a wrong nozzle and it gave me a menu where I could choose the correct nozzle.
It is then that I also noticed that there was a setting for the bed: smooth or textured. It was fixed on smooth but I use the textured.
the printjob started and the menu disappeared.
How can I re-tune this as I intend to switch between nozzle's for the comming print-jobs?
I seem not able to find this in the MK3S-menu.
Settings, calibration, ...
What am I overlooking?
Thx!
RE: Selecting nozzle and bed-surface via printer-interface
Printer detection is a new feature in the printer firmware. You can set it to stop, pause or ignore mismatches. I find it an annoyance since I often switch nozzles and it doesn't really do anything (unlike the bed setting). I simply disable it.
OK, found it in the manual:
SETTINGS -> HW SETUP -> STEEL SHEETS
OR NOZZLE ...
Guess I'll have to wait untill the current printjob has finished to check this out 🙂
see manual (Engl.) p 41 : 8. advanced calibration
