SD init fail
Dominik
(@dominik-7)
SD init fail
Hi all.
I want configure Einsy Rambo 1.2b board with new Marlin 2.0.7.2 version, I want connect to my printer
i2c OLED LCD SSD1306.  Compile Marlin with Platformio , all OK , if start then show message "SD Init Fail"
If remove SD card from SD card slot , on LCD show : "Media Removed" , if insert , show "SD Init Fail".
Can you help with this ? All other working ..
Postato : 04/02/2021 10:04 pm
Utenti
RE: SD init fail
I think you need to adjust the firmware.  Where did you purchase the OLED?
Postato : 05/02/2021 8:48 pm
Dominik
(@dominik-7)
RE: SD init fail
@cwbullet
Hi. I order it on aliexpress 2.4" I2C oled lcd , working , but problem is so original Prusa lcd with sd card slot , encoder not working also . There is problem with marlin 2.0.7.2 . All other (stepper motor, sensors less homing ) working good . https://photos.app.goo.gl/4uqC5GtM8cYWshN3A
And this is oled , original Prusa lcd is only for sd card , encoder , etc https://photos.app.goo.gl/JSb3w2Y1caz5qWrn7
Firmware is problem .
Postato : 05/02/2021 9:36 pm
