SD card reader of the prusa will damage the SD card
Here is a summary of the problem:
- SD Card Recognition Issue: When I insert a working SD card into the printer, the printer displays a "No SD" message, indicating it is not recognizing the card.
- Card Corruption: After attempting to use the card in the printer, the SD card becomes unreadable when reinserted into my computer. It was previously functioning without any issues before being used in the printer.
I have attempted the following troubleshooting steps:
- Tried different SD cards, all of which subsequently became unreadable after being inserted into the printer.
- Formatted the SD cards using my computer before inserting them into the printer, but the issue persists.
- Cleaned the SD card slot to ensure no dust or debris is causing the problem.
- Verified that the printer's firmware is up to date and that the slicer software I am using is the latest version.
I haven't found any solution yet, and I'm afraid that if I buy a new part to replace it, the same thing will happen again. Anyone has experienced the same situation, thank you.
Veröffentlicht : 02/07/2024 1:59 am
