SD card problem !
ericRacer
(@ericracer)
SD card problem !
Hi. i own my prusa mk3s since 3 days and i have a problem with my SD card i got with the printer. The SD card works perfectly with my printers but i am not able to read / write / format it with my PC ? But i have an other SD card (1GB) that my PC can read / write on it.
any idea ?
thanks
Postato : 16/08/2019 11:03 am
RE: SD card problem !
It has the correct format for the printer, and other formats will not work in the printer. Why do you want to format it?
Also - some cards have write protection on them: a small switch on the side.
Oh - wait - your PC won't read it.   If the printer can read the card, I suspect your PC card reader has issues.  Early readers, like those for 1GB cards don't support higher density cards. SD-HD, or SD-XC, etc.  Maybe your reader is too old and not compatible with current SD cards.
Media type Memory card
Capacity
  • SDSC1 MiB to 2 GiB
  • SDHC2 GiB to 32 GiB
  • SDXC32 GiB to 2 TiB
  • SDUC2 TiB to 128 TiB
  • (these are families capacity limits)
Questo post è stato modificato 7 years fa 3 tempo da --
Postato : 17/08/2019 12:41 am
ericRacer
(@ericracer)
Probably you are right , the problem it is the reader of my PC , i didn't realised it was already old . Anyway it works with my 1GB and it is enough for now...
Thanks for your reply...
Postato : 17/08/2019 10:51 am
sterkgix879
(@sterkgix879)
I faced the same SD card problem. when I connect the SD card through USB with my windows 10 OS at that time SD card was not responding. Then I format the data and lost data from card. I lost my important data and searching data recovery service center.
Postato : 05/08/2020 6:05 am
