SD card not recognized
Hi all, ever since upgrading the firmware to 3.10.0 I have two issues:
- " External SPI flash .....etc." I understand that is due to lack of memory on the main board, and the error can be ignored. -> solved.
- The SD card content is not being recognized anymore. I've tried 4 SD cards, all which I've used before. All formatted again. The MK3S recognized that a card is inserted, but then only displays " back" not the card content.
I can still print though Pronterface.
Prusa support mentions that both the main and LCD board should be replaced!
Has anyone encountered the same issue, and maybe found a solution different then replacing both cards?
Thanks in advance.
Napsal : 26/09/2021 5:37 pm
