Sd card melting - is this normal?
Ammar Faridi
(@ammar-faridi)
Postato : 07/04/2023 7:10 am
RE: Sd card melting - is this normal?
I would report this to Prusa! Just log in with your Prusa account and select the eshop. After a few seconds the chat window should appear on the lower right corner. If the chat window does not open, disable a possibly activated adblocker or try another browser.
wbr,
Karl
Postato : 07/04/2023 9:29 am
1 persone hanno apprezzato
Hello
(@hello)
Probably faluty SD card that has been arching or shorting
Postato : 07/04/2023 9:46 am
Do you know whether the card melted in the printer or your computer?
Inspect the sockets with a lamp and magnifier - you may be OK or one of them may need replacing.
Postato : 07/04/2023 12:48 pm
Ammar Faridi
(@ammar-faridi)
I don’t think so.. the card was in printer reader as I was printing petg in enclosure
Postato : 07/04/2023 5:58 pm
Insert a new card.  Access it for a minute or so then cancel and remove it - if it is hot you have a socket based error, if not you had a faulty SD card.
Postato : 07/04/2023 7:04 pm
Hello
(@hello)
If it's still under warranty contact prusa through live chat and they might send new lcd and sd card out
Postato : 07/04/2023 7:06 pm
