RE: Sd card melting - is this normal?
I would report this to Prusa! Just log in with your Prusa account and select the eshop. After a few seconds the chat window should appear on the lower right corner. If the chat window does not open, disable a possibly activated adblocker or try another browser.
wbr,
Karl
Probably faluty SD card that has been arching or shorting
Do you know whether the card melted in the printer or your computer?
Inspect the sockets with a lamp and magnifier - you may be OK or one of them may need replacing.
I don’t think so.. the card was in printer reader as I was printing petg in enclosure
Insert a new card. Access it for a minute or so then cancel and remove it - if it is hot you have a socket based error, if not you had a faulty SD card.
If it's still under warranty contact prusa through live chat and they might send new lcd and sd card out
