Sanity check. Which printer do I have
Kallipigous
(@kallipigous)
I bought the i3 mk3 and updated it to the mmu2. But it's been a while since I printed something and I'm beginning to doubt my sanity. Did I upgrade to MK3s when I upgraded to mmu2? I ask because my printer just told me I had MK3 firmware on the MK3s but I'm not sure that's right.
How can I tell which version I have by looking?
Respondido : 02/06/2020 4:35 pm
vintagepc
(@vintagepc)
Miembro
RE: Sanity check. Which printer do I have
That message means it detected an IR sensor instead of the expected MK3 laser sensor - so yes, you have a MK3S.
Respondido : 02/06/2020 4:45 pm
Kallipigous
(@kallipigous)
What's weird is that I was printing yesterday on the mk3 firmware without any errors.
Respondido : 02/06/2020 4:47 pm
Nikolai
(@nikolai)
Look at your extruder. Chimney design -> MK3s+MMU2s. For more pictures, you can look in the manual. You can find the older and most recent ones online.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 02/06/2020 5:11 pm
Kallipigous
(@kallipigous)
I'm afraid I'm still confused. I have this one which I upgraded when I went to the mmu2. This does have an Ir sensor but it doens't look the same as the mk3s images I see. IUs this a separate hybrid with an IR sensor but not the same as the MK3 S?
Respondido : 02/06/2020 5:33 pm
Nikolai
(@nikolai)
@toby-e
That's correct MK3s and MK3s+MMU2s extruder look different. You have MK3s+MMU2s version.
Often linked posts:
Real Multi Material
Respondido : 02/06/2020 5:37 pm
Kallipigous
(@kallipigous)
Ok, thank you. Too many letters and s' floating about.I'll re-flash, re-calibrate and print. Many thanks.
Respondido : 02/06/2020 6:00 pm
