Safe way to move the print bed in the Y direction
hakonrk
(@hakonrk)
I recently got my first 3D printer  (an MKS3+) and I am wondering about the recommended way to move the print bed. I know that the extruder can easily be moved in the Z direction by pressing the knob for a few seconds, but I don't see any similar function for moving the print bed in the Y direction. Can the stepper motors be damaged if I move the print bed by hand? The reason I'm asking is because I wipe the steel sheet with IPA after each print (to improve adhesion), and sometimes the print bed has been awkwardly positioned.
Postato : 03/02/2022 1:33 pm
The X and Y axes adjustments are buried a little deeper in the menus - but it's safe to move the Y axis, slowly, by hand.  If the screen flickers, slow down a little more.
Postato : 03/02/2022 2:35 pm
2 persone hanno apprezzato
hakonrk
(@hakonrk)
Posted by: @diem
Good to know, thanks! By the way, does anyone know the gcodes for MKS3+ to move the extruder to the top (centered in the X direction) and the bed to the front? Would be nice to add this to the SD card, as a shortcut to get things set up for easy cleaning of the nozzle and bed.
Questo post è stato modificato 4 years fa da hakonrk
Postato : 03/02/2022 2:40 pm
Bob
 Bob
(@bob-2)
RE: Safe way to move the print bed in the Y direction
All of my printers are connected to Octoprint so most of the time I move the axis with the control therein.  But if you look deeper in the menu, perhaps under settings, I don't have my printer on right now, you'll find a move axis menu where you can select which axis to move and by how much at a time.
As @diem says, you can move it by hand, but only if the stepper motors are unlocked, otherwise you have to fight them.  Also as he says move them slowly so you aren't using your servos as generators and back feed the MB.
Cheers
-Bob
Postato : 03/02/2022 3:59 pm
you could try
M104 S210 ; HEAT EXTRUDER TO 210 C
G1 X125 Y210 Z210 ;MOVE AXIS
Postato : 04/02/2022 1:48 pm
