run out sensor
Sirrober126
(@sirrober126)
run out sensor
When the runout sensor is enabled it randomly, does a change filiament .
The machine has a new spool. what may cause this ? everything seems in order.
Best Answer by JoanTabb:
The sensor may be out of adjustment
Which printer so you have.
MK3 uses a different sensor to mk3s. Mk3s+ has a slightly different set up too
Postato : 11/09/2022 2:55 pm
RE: run out sensor
Postato : 11/09/2022 3:27 pm
Sirrober126
(@sirrober126)
RE: run out sensor
thanks Ill check that after this print
Postato : 11/09/2022 4:10 pm
1 persone hanno apprezzato
Clearly a malfunctioning or not properly installed filament sensor. Plenty of articles on the Prusa knowledge base that should tell you what you need to do. Just google for "site:prusa3d.com mk3s filament sensor"
Sirrober126
(@sirrober126)
RE: run out sensor
Fixed it. had to replace 2 parts from wear. the top filiament guide and the guide that holds the metal ball.
Postato : 15/09/2022 2:18 am
