Rods and bearings problems
Nr35
 Nr35
(@nr35)
I assembeld my MK3s about 2 months ago at first my X axis Bearing worked into the Smooth rod
3 days after the replacement arrived my Y Axis Bearing did the same
1 Hour after i ordered the the next replacement i found this... X Axis again is there a Quality problem with the smooth rods and bearings ? i cant imagine an mistake thats could lead to that
This topic was modified 6 years temu by Nr35
Opublikowany : 05/05/2020 10:45 pm
RE: Rods and bearings problems
Did you lubricate the linear bearings on assembly, or afterwards?
Opublikowany : 05/05/2020 11:30 pm
Nr35
 Nr35
(@nr35)
i followed the assembly manual and lubricated first time after 1-2 weeks
Opublikowany : 05/05/2020 11:44 pm
rmm200
(@rmm200)
Lubrication is something you do prior to assembly. The lubricant has to go inside the bearing.
Assembly problems can also crush the bearings into the rods - especially the Y axis U-Bolts of Death.
Don't secure them too tightly.
Opublikowany : 07/05/2020 2:26 am
Nr35
 Nr35
(@nr35)
That means to me that the assembly manual is useless because there was noted the bearings are lubricated and need no further lubrication in the beginning. but the new x axis i pressed the lube all the way thru the Bearings with an adapter before assembly they lastet 3 days
Opublikowany : 07/05/2020 1:14 pm
Dominik,
If I had the power, that would be the first thing I would change...
when I got My Mk1 about five years ago, I instinctively reached for the Lithium grease... and I have greased or oiled, every set of linear bearings since then!
Opublikowany : 07/05/2020 1:41 pm
Nr35
 Nr35
(@nr35)
Since even the spare parts died extra greased after 3 days i ordered a full set of misumi bearings and rods with the recomended grease  i got the printer about 2 months ago and waited 3-4 weeks for spare parts (einsy board lost firmware every  20 minutes of print. X axis and y axis  ) i think i got a monday printer at all
Opublikowany : 07/05/2020 2:59 pm
Looks like you are having a tough time. I hope it gets better for you!
Joan
Opublikowany : 07/05/2020 5:59 pm
