Right z axis sticks only on 2nd M600
thedave42
(@thedave42)
Mitglied
I am trying to print 3 color key caps with a color change at specific layers.  I can print them 1 cap at a time, but this keeps happening when I try and print a batch of 10.  The first M600 gets called with no problem.  When the second M600 gets called the right z axis sticks and causes the x gantry to become misaligned.  The resumed print crashes into the part and the printer fails with an x axis crash.
I have Misumi bearings.  I just went through this process to check, clean, and re-grease them all.  I also removed, cleaned, and inspected the black nuts for that go on the z axis threaded rods (I did not grease them).  They spin freely with no binding all the way up and down the threaded rods.  All my tests pass. Nothing sticks when I move it myself.
I'm using a 0.4 nozzle and tried slicing at both 0.2 and 0.1.  I've tried printing them all over the bed - up front like in the video, in the back, close together in the middle.  I'm running firmware 3.12.2, and using Octoprint to send the gcode.
What else am I missing here?  What would cause this?
Dieses Thema wurde geändert Vor 3 years 2 mal von thedave42
Veröffentlicht : 23/04/2023 7:12 am
Hello
(@hello)
RE: Right z axis sticks only on 2nd M600
I'd say motor swap x and y motor around see if it still does it
Veröffentlicht : 24/04/2023 7:46 pm
It's hard to see from your video - check your trapezoid nuts are correctly fitted, see:
https://help.prusa3d.com/article/check-axis-length-x-y-z-mk3s_134223
In case something went out of line when you greased the bearings run an XYZ calibration:
https://help.prusa3d.com/article/xyz-calibration-mk3-mk3s-mk3s_112351
Your leadscrews are very clean - how have you kept them gleaming?  I wonder if you have been overzealous and are preventing the self lubrication from working correctly.
Veröffentlicht : 25/04/2023 1:05 am
thedave42
(@thedave42)
Mitglied
Posted by: @diem
I think you might have hit on it with the trapezoid nut.  That side's nut had some play on the leadscrew.  I've ordered a new one (actually a couple) and will give that a try.
LOL on the clean leadscrews - they are that clean because I just cleaned them with a brass brush all over as one of the things to troubleshoot this problem.  It took me quite some time to get them that clean. 😀
Veröffentlicht : 25/04/2023 4:29 pm
