[Solved] Revo6 doesn't heat up after the nozzle change
Murat Salmanoglu
(@murat-salmanoglu)
Hi, I searched for a similar topic, but all the ones I could find were about the issues encountered during the initial installation of Revo6. I recently purchased a used MK3S with revo6 installed. I have used it successfully for the last few days. It had 0.4-nozzle installed, and I tried 0.25 and 0.8 without an issue. When I tried to switch from 0.8 to 0.4 today, the nozzle was stuck, probably because of a blob issue I had during the previous print.  I had to use pliers to remove it when the nozzle was cold.
When I installed 0.4 and tried to preheat, I immediately got a thermal anomaly error. I tried thermal calibration, but it does not heat at all and gives a print error. I suspect I somehow broke the heater core, but is there a way to test it to make sure before ordering a new one?
Napsal : 01/03/2025 2:14 pm
Murat Salmanoglu
(@murat-salmanoglu)
RE: Revo6 doesn't heat up after the nozzle change
The problem was the connector inside the cloth sleeve. The pin was out of the connector. When I put it back, it started working.
Napsal : 01/03/2025 7:03 pm
