Restarting instead of performing an action
Jürg König
(@jurg-konig)
MK3 is running amok
Always when the MK3 should perform any action, it’s making a restart.
E.g. I can choose from the menu the point “preheat”. Then the choice of filaments is showed correctly. But as soon as I choose any filament, the printer won’t start preheating, but instead of this makes a complete restart and returns to the main menu again.
If I go to the self-check the check begins with running the check of the two fans and prompts o.k. Then the menu changes to the beginning of the X/Y/Z-checking. But instead of starting the check, the printer restarts again an goes back to the main menu.
As first I reflashed the newest firmware an did all possible resets.
Afterwards I changed the LCD and then the Rambo as well.
But the printer is still restarting as before.
Do you have any idea to solve this problem?
Many thanks!
Veröffentlicht : 11/11/2018 3:55 pm
RH_Dreambox
(@rh_dreambox)
Re: Restarting instead of performing an action
Do you press the round button to confirm the menu selection or do you accidentally press the reset button below the round button?
Veröffentlicht : 11/11/2018 5:56 pm
