Restart when (pre)heating extruder
Currently I cannot print anything at all. It started with a print which was stuck on the extruder. After removing and cleaning thoroughly the printer could not print any parts. So I tried to remove the filament and even this wasn't possible. After selecting unload filament the printer starts to perform the task and within a few seconds the printer restarts itself. The restarts happens even when I want to pre-heat the extruder. Everything else is working. Can anyone help me out with this issue?
Things I tried: cleaning the extruder, firmware update and re-installing the extruder.
Opublikowany : 10/08/2023 5:14 pm
