Resonating bed
JohanN
(@johann)
Resonating bed
Hi i have this problem... i alraedy took the headed bed off.. and it has still play on the barring i think it needs replacement or is this normal?
see movie
IMG_9226
Napsal : 31/05/2021 9:48 am
RE: Resonating bed
Posted by: @johann
see movie
IMG_9226
What kind of play do you have in bearings?  Which Bearings?
Napsal : 31/05/2021 1:31 pm
RE: Resonating bed
Posted by: @johann
see movie
IMG_9226
- Linear bearing U-bolt screws not tightened enough
- defective linear bearings
- too much backlash on the linear rods
Napsal : 31/05/2021 2:17 pm
JohanN
(@johann)
RE: Resonating bed
@cwbullet
OEM barrings from Prusa, Printer is 1 week old and noise is getting more.. as more i print.. i will get the bed of and see how much play it is..
thanks
Napsal : 31/05/2021 2:34 pm
JohanN
(@johann)
RE: Resonating bed
Posted by: @karl-herbert
Posted by: @johann
see movie
IMG_9226
checked and tight
Iam thinking that
also tight and no movement
Napsal : 31/05/2021 2:38 pm
RE: Resonating bed
@johann
checked and tight
Take care, if they are too tight they will damage the bearings.  They should be *just* tight and then a quarter turn more.
Napsal : 31/05/2021 3:14 pm
RE: Resonating bed
Posted by: @johann
see movie
IMG_9226
I agree with Karl and the others.  That will create all of the problems as you describe them.  Keep us up-to-date.
Napsal : 31/05/2021 3:20 pm
Baklin
(@baklin)
RE: Resonating bed
If that printer is a week old it is a MK3s+. That doesn't have the u-bolts but the news bearing clips. The instructions are different than for the u-bolts. The bearing clips should be fully tightened. (with normal force, these are just m3 bolts)
Napsal : 31/05/2021 6:31 pm
