Resetting at preheat or filament load
Christopher
(@christopher-8)
Guidance welcome -- Mk3s reboots on a filament load or preheat.   I've the bed turned off for filament loads.
I've replaced the hotend thermistor/heater cartridge.  Is this a rambo or psu issue?
Postato : 05/08/2025 2:22 am
Artur5
(@artur5)
RE: Resetting at preheat or filament load
A couple of questions :
When you switch on the printer, the temperatures of nozzle and bed are correct ?  ( i.e. room temperature ).
Are you able to start heating the bed without problems and the screen shows a progressive increase in the temp. of the bed ?.
If the answer to both questions is yes, and the hotend thermistor//heater cartridge are OK.  then it must be the Einsy board, as you suspect.
Just to be sure about that, if you have access to a multimeter, disconnect the cables of the heater cart. and thermistor hotend in the Einsy board and check the resistances of both components ( around 100-125 KOhm for the thermistor and 14-15 Ohm for the cartridge).
Additionally, with the cables of the heater cart. disconnected, see what happens when you try to load filament ( or heat the nozzle).
Postato : 05/08/2025 8:43 pm
Christopher
(@christopher-8)
Thank you for responding!
Posted by: @artur5
Correct.  They register correctly.
I couldn't heat the bed on a mk3 without the nozzle, but shutting off the bed heating on the filament reload didn't get rid of the issue...  I think I ruled the bed out.
I replaced the complete hotend with another V6 with a hardened nozzle I had sitting to the side to remove the extruder from the equation
They both test within those specifications, and the same as the ones i removed.
I'll try that next.   Running a voltage check on the PSU will probably not reveal anything.   I don't think I have an equivalent PSU sitting around to swap out.  If it's the EINSY rambo, I may be convinced todo a mki3.5 upgrade rather than buy a new rambo... if its the PSU.. well you just gotta buy one of them.   Am I missing anything?
Postato : 05/08/2025 9:50 pm
