Replacement of heat block and heat break
Maj
 Maj
(@maj)
I have to replace heat block and heat break on my prusa MK3 (already broken after 4 months only 😡 ) and I just wanted to order it in the prusa shop but it is no longer in stock, so I was looking for an alternative... As I am really new to all of this, I would like to have someone more experienced to confirm, that this is actually the same component than at the MK3 (the heartbreak for example doesn't have the red stripe, no idea if that is important):
https://www.123-3d.nl/E3D-v6-heaterblock-bevestigingsmaterialen-origineel-oude-versie-i2222-t13090.html
https://www.123-3d.nl/E3D-v6-heatbreak-1-75-mm-origineel-i272-t15044.html
Can I buy those things?
Ps. I think this is one of the only sellers that ship to the netherlands, hope it is professional.
Thanks for you help!
Respondido : 19/06/2018 5:05 pm
Re: Replacement of heat block and heat break
Hi.
Sorry i don't speak your language,
I believe the heatbreak is ok but the heatblock is wrong
try https://www.123-3d.nl/E3D-v6-heaterblock-bevestigingsmaterialen-origineel-i312-t15044.html
Respondido : 19/06/2018 7:14 pm
Maj
 Maj
(@maj)
Oki, thanks a lot! 🙂
Respondido : 20/06/2018 8:55 am
Good Luck!
Regards Joan
Respondido : 20/06/2018 3:07 pm
