Replacement hot end - extruder head
Jeff
 Jeff
(@jeff)
I need a new extruder head (hotend) but I cannot find a way to order it.
The orange insulated wires broke off while I was doing the upgrade to MK3S,
Napsal : 10/10/2019 7:04 pm
RE: Replacement hot end - extruder head
Go to the Prusa eShop, make sure you are logged in,
look in the Mk3 spares list
consider getting a spare 24volt heater and extruder thermistor, plus PTFE Tubes for the extruder, and you can replace the existing kit, to get going quickly, and repair the old one for standby!
or you could order direct from E3d or one of their distributors!
Napsal : 10/10/2019 9:39 pm
Jeff
 Jeff
(@jeff)
Thank you!  I could not find the spares before
Napsal : 11/10/2019 1:20 am
I keep one new one in the house at all times.  if you replace the heat cartridge or thermister, use a heat gun and plier before you use an Allen wrench.
Napsal : 11/10/2019 12:33 pm
