Repairing the lead wire connection on the print fan
Glenn
(@glenn-2)
Does anyone happen to know which lead wire goes to which pad on the pcb inside the print fan? I need to repair this while I wait on a replacement. Thank you!
Postato : 21/11/2021 5:43 pm
Swiss_Cheese
(@swiss_cheese)
@glenn-2
Hope this helps.
Swiss_Cheese
The Filament Whisperer
Postato : 21/11/2021 11:17 pm
Glenn
(@glenn-2)
RE: Repairing the lead wire connection on the print fan
Thank you!!
Postato : 22/11/2021 4:09 pm
Utenti
I would recommend you keep at least on spare.   This will happen again.
Posted by: @glenn-2
Thank you!!
Postato : 22/11/2021 4:14 pm
Dan Rogers
(@dan-rogers)
Print the service shelf - it will save your fans
In the print library is a oh so useful service shelf that hangs on the X horizontal rods.  It is used to service the extruder body and designed to hold the fans without breaking their little wires.
Postato : 23/11/2021 11:27 am
Utenti
Is this it?
https://www.prusaprinters.org/prints/3470-prusa-printers-service-tray
Posted by: @dan-rogers
Postato : 23/11/2021 11:48 am
1 persone hanno apprezzato
Dan Rogers
(@dan-rogers)
That's it!  I have two of them.  They save your fans.
Postato : 23/11/2021 12:00 pm
Glenn
(@glenn-2)
Great idea. Thank you
Postato : 23/11/2021 12:01 pm
Glenn
(@glenn-2)
Thanks for the link!
Postato : 23/11/2021 12:02 pm
Utenti
thank you!
Postato : 23/11/2021 12:03 pm
Utenti
Eventually, you arw going to damage the fan fires to the point where it cannot be repaired.  I have been doing this for almost 4 years.  Sometimes, it is time to swap it out.
Posted by: @pkmount
Posted by: @cwbullet
Posted by: @glenn-2
Thank you!!
I don't thinks so, Why just, I don't think anything that adds to this can improve! can you explain how?
Postato : 25/11/2021 12:11 pm
Carbon658
(@carbon658)
Does anyone know the polarity of the wires on the original fan? I need to replace mine and have an extra Fysetc DC5V radial fan.
I'm assuming that:
Red = Positive
Black = Negative
Yellow = Speed
Can anyone confirm this?
Postato : 13/11/2023 9:14 pm
