Removing SD while printing
JonB
 JonB
(@jonb-2)
I was just wondering if the i3 MK3 loads the gcode from the SD to memory prior to printing. I would like to be able to load the next item onto the card before the first has finished.
Obviously I can just buy two cards but I thought I would check.
Posted : 28/02/2019 10:09 am
wieman01
(@wieman01)
Re: Removing SD while printing
I have not tested this after the latest firmware upgrade, but what I can say is that it has not been possible so far. You remove the SD card, the printer stops. Period. In my opinion this is not the smartest behavior I could think of.
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
Posted : 28/02/2019 1:57 pm
The printer has a very small amount of memory to work with. It is not buffering the entire gcode file.
Posted : 28/02/2019 4:31 pm
